Date/Time: Tue, 22 Apr 2025 10:32:31 +0000
Swapping CQG to Denali Feed
View Count: 307
[2023-03-06 18:33:08] |
User795404 - Posts: 1 |
Dear Sierrachart I am new to trading, and curious if my live amp trading account counts towards my non-professional trading status to swap to a Denali feed on your platform for $34.25 month? Or do i need to swap to a more suitable equivalent to AMP? |
[2023-03-06 21:32:16] |
If, when you setup your AMP account, you told them you were going to use Sierra Chart, then they would have set you up to use CQG for your order routing. If this is the case, or if they have you setup with Rithmic, then you can use this account to qualify for the non-professional exchange fees for the CME Group. To connect your Sierra Chart to CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions Or, to connect your Sierra Chart to Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions Once you have the above done, then, if you have not already done so, setup the Denali Exchange Data Feed by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
