Date/Time: Thu, 28 Nov 2024 09:44:41 +0000
Using Live Account Realtime Denali Data on Trading Evaluator Connection
View Count: 379
[2023-03-06 12:21:28]
User624595 - Posts: 207
Have translated symbols. How can get existing realtime Denali feed from live account, working on SC Trading Evaluator connection?
[2023-03-06 13:22:06]
Sierra_Chart Engineering - Posts: 17201
Nothing special to do.
However:
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes.
[2023-03-06 17:19:45]
Allow SC Feeds is set to Yes, connected to Trading Evaluator (trading), translated symbols, realtime data that works on live account is not updating charts with Evaluator connection.
Quoteboard won't populate.
Error attached shows up, but cannot click on it.
image2023-03-06_12h14_08.png / V - Attached On 2023-03-06 17:18:07 UTC - Size: 3.31 KB - 80 views
[2023-03-06 21:06:11]
John - SC Support - Posts: 36350
If you are still having an issue, then we need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-03-07 06:07:12]
Looks like data is coming through OK, problem is with translating all of the symbols in all of the instances from the IB ones to SC Evaluator format. The ones with exchange CBOT seemed to translate ok, ones with exchange CME, COMEX, NYMEX seem to not be translating.
[2023-05-07 11:52:36]
Give us the exact symbol that is not translating and tell us, what is the Current Selected Service set to in Global Settings >> Data/Trade Service Settings.
Date Time Of Last Edit: 2023-05-07 11:52:44
