Date/Time: Tue, 22 Apr 2025 10:17:26 +0000
Copy certain drawings to another chart
View Count: 571
[2023-03-06 12:03:04]
58LesPaul - Posts: 429
Is there a way to copy just certain types of drawing tools to other charts but not all? I want Horiz Line non extended and Rectangle to copy to another chart but not any other drawing tool.
[2023-03-06 18:25:59]
John - SC Support - Posts: 39395
You would have to set the drawings that you do not want to copy by disabling the option for Allow Copy to Other Charts. Refer to the following:
Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied
You can then use the standard copy drawings from another chart option. Refer to the following:
Copying Chart Drawings from Other Charts Automatically: Copying Chart Drawings from Other Charts
