Date/Time: Tue, 22 Apr 2025 10:14:25 +0000
Adding VWAP to the Footprint Window
View Count: 425
[2023-03-06 09:20:04] |
User885565 - Posts: 17 |
Hi, When I add in support and resistance levels onto the market profile window these levels are visible on the footprint window (and also to the Day VWAP window) which is super useful. Is there a way of making the VWAP level visible on the Footprint window? I can't see a way to do it so I am appealing to the boffins! :) Thanks in advance for your help. |
[2023-03-06 13:20:40] |
Sierra_Chart Engineering - Posts: 19305 |
We do not know what you mean by "footprint window". Do you mean a chart with the Numbers Bars study?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-06 13:20:50
[2023-03-07 01:46:41] |
Hi, I am so sorry for being imprecise. Yes it is the volume at price level bar study as shown in the uploaded jpg picture. Thanks again. |
[2023-03-07 07:58:50] |
Still we are not very clear on all of this. There is no study named "Volume at Price level bar". Maybe you need to set the Scale Range for the study to Automatic: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-07 08:00:00
[2023-03-07 08:19:43] |
I had included a screenshot of the window in question which I hoped would help identify what I needed - but no problem. Anyway - after much searching through I have managed to put the VWAP in a study for that page which hopefully will work. Thanks for taking the time. |
