Date/Time: Tue, 22 Apr 2025 07:30:37 +0000
Is it possible to send orders from a Sierra sim account to an IB sim account?
View Count: 302
[2023-03-06 03:57:23] |
trader2017 - Posts: 117 |
In the past I have sent orders from Sierra to a real Interactive Brokers funded account and everything worked very well. I do not have an account at IB at this time, but if I set up an account with them is it possible to send orders from a Sierra simulation account to an IB simulation account? Thank you. |
[2023-03-06 09:21:42] |
Sierra_Chart Engineering - Posts: 19295 |
Yes. You just simply connect Sierra Chart to your Interactive Brokers account, whatever kind it is and then disable Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-06 09:21:53
