Date/Time: Tue, 26 Nov 2024 19:42:17 +0000
LTCCNY-OKCOIN showing .. could be BTCCNY
View Count: 1154
[2014-06-15 00:38:08]
oyvinds - Posts: 28
LTCCNY-OKCOIN in Sierrachart went from 60s (which is normal) to 3650s 4 days ago. 3650 is about 587 USD which is the Bitcoin price.
I believe your servers have been confused and now believes that the Bitcoin price is now also the Litecoin price and shows the BTC price at OkCoin for SierraChart symbol LTCCNY-OKCOIN. This is not the case and I am sure this is a huge disappointment to Litecoin longs everywhere.
imagewtf.png / V - Attached On 2014-06-15 00:35:02 UTC - Size: 78.52 KB - 357 views
[2014-06-15 04:05:39]
We are checking on this.
[2014-06-15 07:13:25]
This is now solved.
The incorrect data has been deleted. Right click on the chart before those higher prices and select Delete and Download Data.
[2014-06-15 08:17:17]
oyvinds - Posts: 28
Thank you for your quick response. It does appear to be a gap (period in question missing) in the data after delete and download data. I am fine with it and I guess nobody anywhere cares even a tiny bit about that gap. Ticker/chart works, thank you.
Date Time Of Last Edit: 2014-06-15 08:26:47
[2014-06-15 08:48:13]
Yes, we should have mentioned that there is a gap of data. We checked to see if we could get the historical data from another source and we could not.
