Date/Time: Mon, 15 Dec 2025 09:28:36 +0000
Trial Activation
View Count: 432
[2023-03-05 18:02:09]
User466872 - Posts: 6
I tried activating trail but did not receive SMS. I'm from the UK and used the correct phone number format.
447484......
[2023-03-05 19:45:33]
Sierra_Chart Engineering - Posts: 21843
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
