Date/Time: Tue, 22 Apr 2025 07:54:29 +0000
Study position in list changes looks of study
View Count: 376
[2023-03-05 12:14:13]
58LesPaul - Posts: 429
In each screenshot the 50 day MA for volume is selected and changes depending on where the study is located in the list. If the MA-Simple study for volume is first or second on the list the 50-day MA average for volume is much higher than if it is 3rd through 6th position on the list. Does the position in the Studies list supposed to change the results?
imageScreenshot 2023-03-05 060317.png / V - Attached On 2023-03-05 12:12:48 UTC - Size: 98.01 KB - 88 views
imageScreenshot 2023-03-05 060343.png / V - Attached On 2023-03-05 12:12:54 UTC - Size: 99.9 KB - 82 views
[2023-03-05 13:14:52]
User431178 - Posts: 654
Are you sure it is not just the scale range changing?
When MA is first in list scale range is based on MA, but when volume is first then scale is based on volume.
Chart Studies: Scale Values
[2023-03-05 14:27:56]
OK, thanks you.
