Date/Time: Tue, 26 Nov 2024 14:30:49 +0000
TPO charts lagging
View Count: 498
[2023-03-05 10:16:19] |
Imperia_victoriam - Posts: 6 |
TPO charts are very slow and lagging in my sierra chart terminal. Can you please provide a step by step solution to this?
[2023-03-06 17:47:45] |
John - SC Support - Posts: 36286 |
For the TPO itself, check that your Letter/Block Price Increment in Ticks is set to a reasonable value. Having this too small will increase the processing required and could cause the sluggishness you are seeing. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks Beyond the TPO study itself, refer to the following for general ways to improve performance of the system: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-09 15:56:42] |
Fredrik Persson - Posts: 4 |
Same for me after latest update, big differense in prestanda? What to do? Regards, Fredrik |
[2023-03-09 17:52:19] |
Please go through the same items we stated in Post #2.
[2023-11-15 02:13:19] |
AbdulazizKHF - Posts: 4 |
What is a reasonable value for example?
[2023-11-15 03:07:58] |
Sierra_Chart Engineering - Posts: 17179 |
A reasonable value for what?
