Date/Time: Tue, 22 Apr 2025 10:23:19 +0000
Change default time in force setting in DOM
View Count: 329
[2023-03-05 05:08:08] |
User924125 - Posts: 14 |
Hi, is there a way to change the default time in force selection on a trading DOM to be "Good till Canceled". I understand that if I save the chartbook with the DOM open, it will save the DOM time in force settings, but if I open up a new trading DOM, the time in force reverts back to Day. |
[2023-03-06 17:43:18] |
Yes, this will be the case. As you state, one option is to save the Trading DOM with the Chartbook. The other option is to select a Trade Configuration that you have previously saved. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
