Date/Time: Tue, 22 Apr 2025 10:29:16 +0000
order flow
View Count: 521
[2023-03-03 17:45:22]
parth PAtel - Posts: 1
how can i open order flow chart for us stock
[2023-03-06 15:18:28]
John - SC Support - Posts: 39395
On Sierra Chart the study you want is called "Numbers Bars". Refer to the information at the following link:
Numbers Bars: Step-By-Step Instructions
You are not currently setup to receive real-time data from us for U.S. Stocks, therefore you would want to use our Delayed Streaming Data Feed for the NASDAQ TotalView data. This will act just like real-time data, but is delayed by 15 minutes. The one thing you need to do is to add the suffix "-NQTV" to the end of the standard stock symbol, in order to get this data. So rather than entering IBM for the symbol, you would enter IBM-NQTV. Refer to the following for more information on the NASDAQ TotalView data:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
And also refer to the following regarding the Delayed Streaming Data Feed:
Delayed Exchange Data Feed
