Date/Time: Tue, 22 Apr 2025 10:23:22 +0000
Trade Window
View Count: 344
[2023-03-03 16:49:50] |
User585993 - Posts: 83 |
If I change the quantity of the contracts at the trade window, say from 2 to 3 contracts, the change only works with SIM, it doesn't apply with live mode. any idea what's wrong? Thanks in advance |
[2023-03-03 17:36:25] |
We need more information on what exactly you are doing. Changing the quantity on the Trade Window does not do anything to existing positions.
[2023-03-03 17:53:21] |
I mean entering a new position, I use a simple bracket as you can see in the attached image
[2023-03-06 15:33:32] |
But what exactly occurs when you change from Sim to Live? Is it just the main quantity, or is the quantity of the targets changing? There should not be a change in quantity when you are just switching from Sim to Live. So we need to understand what is occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
