Date/Time: Tue, 22 Apr 2025 23:11:29 +0000
Studies
View Count: 385
[2023-03-03 16:40:38] |
Daniel Gonzalez - Posts: 14 |
If I share my chart, is there a way to prevent others from seeing the studies I use?
[2023-03-03 17:33:58] |
John - SC Support - Posts: 39428 |
There is not a way to prevent studies from being seen. The one option that is available is to Password Protect the studies themselves. But the study itself is still viewable, just the specific Inputs are not viewable. Refer to the following: Chart Studies: Password Protecting Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-03 17:34:21
[2023-03-29 20:01:12] |
that worked! and how can I see the settings once again?
[2023-03-29 20:44:43] |
Open the study settings for that study and deselect the option for "Password Protect". You will be prompted for the password, enter it properly to undo the password protection.
