Date/Time: Tue, 22 Apr 2025 06:57:05 +0000
Trouble with alert sounds for Spreadsheet System for Trading
View Count: 555
[2023-03-03 13:04:21] |
User247273 - Posts: 37 |
Here's my situation: 1. In the General Settings window, I have assigned a sound file to Alert 100 on the Alerts tab. 2. In the Spreadsheet System for Trading study, I have Column K Alert set to Alert 100. On the Alerts tab for this study, the boxes for "Eneabled" and "Alert Only Once per Bar" are checked. 3. I have a formula in column K which evaluates to TRUE several times each day and outputs a value of 1 in column K. 4. The arrows I have set for SG1 (column K) plots properly on the chart when column K evaluates as TRUE. 5. No alert sound ever plays when column K evaluates as TRUE and nothing shows up in my Alerts Log. I have read the help docs below but I can't seem to figure out what I'm doing wrong. Any andvice would be appreciated. Spreadsheet Systems, Alerts and Automated Trading: Sound for Audible Alert and E-Mail Message Notifications Spreadsheet Systems, Alerts and Automated Trading: Column [K, L, M, N, O, P, Q, R, S, T, U, V-Z] Alert General Settings Window: Troubleshooting for Alert Sounds That Do Not Play |
[2023-03-03 13:18:22] |
One last thing in case there's any relevance... I have 6 charts in my chartbook, all of which have a Spreadsheet System for Trading study applied. Each of the 6 studies is using it's own sheet within a common spreadsheet file. All 6 instances of the Spreadsheet System for Trading study are functioning as described above (i.e. all good except no sound alerts being triggered). |
[2023-03-03 16:36:20] |
The alerts for columns K, L, M, and N will only sound when you are sending a trade.
