Date/Time: Tue, 22 Apr 2025 07:54:30 +0000
Quantity precision not exact
View Count: 267
[2023-03-03 11:38:55]
User251043 - Posts: 47
I send a Limit Buy order to the Exchange server and it is accepted and filled later.
The order amount is 0.005, and the server accepts it perfectly; later the order is filled (0.005). The problem is this: my SC terminal insists that the quantity is not 0.005 (the one I typed, the one sent to the server and the one executed in reality), but SC shows me an order fill of 0.004999999999999999, so SC thinks there's a remaining quantity of 8,6e-19. SC recalculate the e-19 as "filled" and then types an order fill triangle of 8,6e-19, so when I open a position of 0.005, instead of seeing 1 triangle, I see 2 triangles. See the attached file. It's very difficult to review the session.
What can I adjust in settings to avoid having that e-19 positions? I suppose it's a problem about floating numbers, but it's quite difficult to follow the session.
Thank you very much.
imageimagen_2023-03-03_123126346.png / V - Attached On 2023-03-03 11:31:28 UTC - Size: 7.01 KB - 78 views
[2023-03-03 11:40:59]
Sierra_Chart Engineering - Posts: 19299
We need to add a new setting to control the number of decimal places. We will work on that.
Date Time Of Last Edit: 2023-03-03 11:41:33
