Date/Time: Tue, 22 Apr 2025 07:36:26 +0000
Revers 2 contracts or more
View Count: 355
[2023-03-03 10:42:39] |
SkyKeeper - Posts: 40 |
Hello, there is a problem in release 2470, service rithmic The attached orders are used: target limit 20 ticks, stop 10 ticks. If you use 1 contract, the reverse button works normally and reverses the position, and if you use 2 or more contracts, then the reverse button must be pressed twice, the first time it does cancel all and the second time it reverses |
[2023-03-06 01:15:54] |
Sierra_Chart Engineering - Posts: 19297 |
This is not a problem with Sierra Chart. The issue might be related to this: Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded You should not have this kind of problem when using Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-06 01:16:43
