Date/Time: Tue, 22 Apr 2025 07:19:34 +0000
Hedging Possibility / Study Overlay or Spreadsheet Study, etc / Positions in one Chart
View Count: 338
[2023-03-03 07:53:47] |
User871209 - Posts: 91 |
Hello, If I am hedging a position using two separate accounts in SC is there a way to show the two positions in one chart? Maybe using Study Overlay or Spreadsheet Study (Line, dot, etc) to show the entry in one single chart, the idea is to be able to have a visual reference in one chart of both positions Any thoughts would be appreciated, Thanks, |
[2023-03-03 09:57:54] |
Sierra_Chart Engineering - Posts: 19293 |
If they are separate accounts, the answer is no. But you can see them in Trade >> Trade Positions Window. You could develop the ability to see both positions using ACSIL: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
