Date/Time: Tue, 22 Apr 2025 07:22:14 +0000
How to see if a study is referenced by another study/chart?
View Count: 394
[2023-03-02 23:18:50]
joshtrader - Posts: 506
I'm sorry but I couldn't find the answer in the docs: is there a way to see if another study (whether on the same chart or a different one) is referencing a given study? I want to remove a study from a chart, but I'm unable to tell without exhaustively searching all other charts whether the study is being referenced elsewhere.
Date Time Of Last Edit: 2023-03-02 23:21:51
[2023-03-03 15:25:10]
John - SC Support - Posts: 39395
There is not a definitive way to see if studies reference other studies. The Study/Price Overlay gives you the name of the chart that is being referenced in the Chart Studies window, but that is just that one study.
Just in case it is helpful, you can see what other charts are referencing a specific chart looking at the header of the Chart Settings window. Refer to the following:
Chart Settings: Determining References to Chart
