Date/Time: Tue, 22 Apr 2025 07:45:53 +0000
chart replay mode
View Count: 359
[2023-03-02 18:45:30] |
User500142 - Posts: 2 |
Hey i wanna go back from 2015 and use chart replay mode but when i click on chart replay mode doesn't matter what date i keep it starts from april 2022 what can i do to resolve this issue as i wanna use chart replay mode from 2015??
[2023-03-02 22:07:22] |
Do you have data in the chart going back to 2015? I sounds like you only have data going back to April 2022. You can only do a replay with the data that is in the chart. Refer to the following information: Replaying Charts: Replaying Chart from Specific Date-Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
