Date/Time: Tue, 22 Apr 2025 07:45:52 +0000
Volume Profile
View Count: 304
[2023-03-02 18:42:58] |
Kadden Wilson - Posts: 3 |
I Would just like to know why my Volume Profiles are not allowing me to erase them after they are drawn up.
[2023-03-02 22:04:35] |
You should be able to delete them, depending on a couple of settings. Check the following: - Tools >> Tool Settings >> General >> Select Drawn Volume Profile by Outline Only: If this is set to Yes, then you have to select the Drawn Volume Profile by the outline, which can be hard to do. Refer to the following: Chart Drawing Tools: Select Drawn Volume Profile by Outline Only (Global Settings >> Tool Settings >> General >> Volume Profiles) - Tools >> Tool Settings >> General >> Enable Drawn Volume Profile Selection: If this is set to No, then you will not be able to select the Drawn profile in order to delete it. Refer to the following: Chart Drawing Tools: Enable Drawn Volume Profile Selection (Global Settings >> Tool Settings >> General >> Volume Profiles) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
