Date/Time: Tue, 22 Apr 2025 07:08:34 +0000
Tile 2 charts
View Count: 380
[2023-03-02 13:30:37]
OriolCasas - Posts: 189
I want to tile 2 charts of my chartbook (I ahve more than 8 charts on the chartbook, I only want to tile two of them)
How can I do that?
Thank you
[2023-03-02 17:45:14]
John - SC Support - Posts: 39395
What you have to do is to tile all the charts, then minimize all the charts you do not want. Then when you are down to the 2 charts, select the tile option you want again, and it will tile just the two charts.
[2023-03-02 18:06:03]
Ok I did that. But then when I go to anither chart (one that is not on the 2 tiled charts) The 2 charts that are tiled get untiled.
Is that normal or is there anyway that I acn roevent this from happening?
[2023-03-02 18:51:04]
We are not understanding the exact situation that you are trying to explain. Please give us some additional information on what you are doing and what is happening.
