Date/Time: Mon, 15 Dec 2025 09:28:35 +0000
1:1 Energy Spreads
View Count: 558
| [2023-03-02 00:33:58] |
| User417302 - Posts: 69 |
How would I go about creating a chart to track the 1:1 spreads in crude/gasoline and crude/heating oil? Also I want to be able to chart the crude oil natural spread as well. Whereby buying 1 crude and selling 1 natural gas contract and vice versa. Thanks, |
| [2023-03-02 16:50:47] |
| John - SC Support - Posts: 43443 |
If these spreads are not available directly from the exchange, then you can create the bars for these situations using our Custom Calculated Symbols. Refer to the information/instructions at the following link: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
