Date/Time: Mon, 25 Nov 2024 23:28:24 +0000
[User Discussion] - Range Reversal Bar chart
View Count: 1545
[2023-03-01 20:23:35]
pstn - Posts: 3
I just made the switch to Sierra Charts, I'm looking to get the same kind of charts I used on ATAS and Exocharts. ATAS calls it a RangeUS Charts (not range chart) and exocharts calls it Trend Rev Charts. The candle look like on the picture attached. Can anyone tell me if this is available on Sierra Charts? I can post more details on the candles, but I don't know if I'm allowed to link to documentation pages of competitors.
The reversal bars that are available on Sierra don't act like ATAS and Exocharts, I tested them.
here are the settings for them.
The RangeUS chart consists of two candle types:
Trend;
Reversal.
Three parameters are used when building them:
Tick Trend – is a distance, achieving which a trend candle will be formed and closed. The distance is measured either up or down;
Tick Reversal – is a distance, achieving which a reversal candle will be formed and closed. A mandatory condition for closing is a back (opposite) price movement in relation to a previous candle;
Open Offset – is a shift from the session beginning, from which the first candle starts. Using this parameter affects the whole chart, since it shifts the rigid boundaries.
imageCapture.PNG / V - Attached On 2023-03-01 20:20:41 UTC - Size: 96.59 KB - 257 views
[2023-03-02 15:27:09]
John - SC Support - Posts: 36286
Check the Renko Bar options, particularly the Flex Renko. Refer to the following:
Renko Bar Charts
[2023-05-12 21:53:15]
User13051990 - Posts: 26
Hello, I am also interested in "building" this chart in SierraChart.
pstn, Please send me a dm.
Greetings!
[2023-11-01 14:29:59]
Wernitschanton - Posts: 24
Is there any update on this. I would also be interested in the Range US and Range X Bar types
[2023-11-02 21:34:12]
Hey. I tried lots of things to „rebuild“ this Chart. I was not successfull.
My solution was to use ATAS for RangeUS Charts and Sierra for the rest.
If you are successfull in rebuilding it, please let me know.
Greetings!
[2023-11-03 08:41:11]
Hey friend.
I´m currently using the Flex Renko inverse Bars.
My Settings are 8-8-8. Gives a similar look and seignals than RangeUS or TREV
Hope that helps
image1.png / V - Attached On 2023-11-03 08:37:19 UTC - Size: 144.59 KB - 188 views
[2023-11-08 21:25:55]
Hey! Thank you for your answer. Could you please upload a screenshot of your chart settings? My chart still looks different to yours, even I chose the same settings you described in your text.
[2024-01-23 19:59:53]
pasarn - Posts: 3
It works when trend and reverse are identical. But I need diverent settings for trend and reversal bricks.
