Date/Time: Tue, 26 Nov 2024 00:42:33 +0000
Saving Order Allocation list
View Count: 677
[2023-03-01 16:51:50] |
Trade Dojo - Posts: 45 |
Is is possible to save the list of accounts in Order Allocation list? The reason is when I have multiple accounts and would like to sub-group it. When changing the group, I have to manually remove and add individuals.
[2023-03-01 23:16:22] |
John - SC Support - Posts: 36286 |
There is not a way to save the list or to create groups. It just works on adding/removing individual accounts.
[2023-12-24 23:19:00] |
ReadTheTape - Posts: 5 |
Is it possible to add this feature to save multiple Order Allocation Lists?
[2023-12-24 23:20:53] |
Sierra_Chart Engineering - Posts: 17178 |
Yes we will do that. Just give us about a week or so.
[2023-12-29 01:54:42] |
We apologize but this is more involved than we were originally thinking. We decided against working on developing this capability. What we will do though is support having Order Allocation to Trade Accounts to be saved with Trade Window configurations. Maybe this is what you were thinking anyway. This should not be too difficult.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-29 02:02:21
[2023-12-29 02:55:12] |
This work-around sounds great! Looking forward to testing this out when it gets implemented. Thanks.
[2023-12-30 03:18:49] |
user_xyz - Posts: 416 |
Has this been implemented yet? My solution was to create an entirely new installation of Sierra Chart to handle all the accounts (acting like a sub group) vs adding and removing all the individual accounts (major pain do this one by one). |
[2023-12-30 23:22:55] |
No not yet. And it will be a global option to be able to save the list of accounts for Order Allocation as part of the Trade Window configuration.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-30 23:23:21
[2024-01-17 03:50:58] |
It looks you all added this functionality. I can add accounts to the Order Allocation -> Allocation List then save the configuration and it will load the accounts I had saved in the Trade Window configuration. Is there a way to save the default account selected and load it with the list of accounts? It's confusing to remember which account is the 'master' for the list of accounts wanting to load. Thanks for adding this BTW big time save. |
[2024-01-17 07:08:00] |
works great ... thanks for adding this feature.
