Date/Time: Tue, 22 Apr 2025 07:27:50 +0000
Problem with order templates
View Count: 284
[2023-03-01 15:57:22] |
User427421 - Posts: 43 |
I keep having this issue with my order template. I have a template that takes profit on 3 contracts out of 5 at the 1st target (screenshot attached). But for some reason if I am in a trade and want to add or exit some contracts and I temporarily uncheck "use attached orders" then the next time I enter a trade my template is changed and the 1st target only shows 1 contract instead of 3. I'm assuming this is a bug...
Date Time Of Last Edit: 2023-03-01 15:58:55
[2023-03-01 18:14:19] |
Sierra_Chart Engineering - Posts: 19295 |
This is normal and expected if the order quantity on the Trade Window is changing. What you need to do, is save your Attached Order configuration as you require it and then when you want to use it, reselect it. Refer to: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 18:15:11
[2023-03-01 18:40:13] |
ah, that makes sense. thanks
