Date/Time: Tue, 22 Apr 2025 07:11:37 +0000
auto trade program
View Count: 315
[2023-03-01 15:48:16] |
bala - Posts: 74 |
I have auto trade execution setup. The setup reads value from charts (using sc.GetStudyArrayUsingID). Most of the time it executes well. When I change the setup to use different values (say swtich to to a 50MA instead of 200MA) the chart doesn't execute ( I stop sierracharts and restart again) do I need to refresh or is there a parameter to set? Thanks Bala |
[2023-03-01 18:53:51] |
Sierra_Chart Engineering - Posts: 19293 |
Definitely a restart should never be needed. You need to troubleshoot this. Refer to: Automated Trading From an Advanced Custom Study: Debugging/Troubleshooting Automated Trading Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 18:54:22
