Date/Time: Thu, 19 Sep 2024 01:14:16 +0000
rollover data
View Count: 1106
[2014-06-13 13:40:24] |
mogull - Posts: 40 |
From YM I don't get back data to Sept. When I do the rollover it doesn't highlight the box to include the data. I "erased and reloaded" the data. Tried several times and things. Version 1077. Thanks Alan |
[2014-06-13 17:02:07] |
Update Sierra Chart to the current version with Help >> Download Current Version. After that you need to use the new Continuous Futures Contract feature: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-13 21:48:24] |
Doesn't work. http://www.sierrachart.com/image.php?l=1402696024121.png That is what my chart looks like. I've done it before and it worked. |
[2014-06-13 22:45:40] |
This chart does not have one of the Continuous Contract options selected. Refer to the step-by-step instructions here: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-14 01:26:50] |
Well I found that. And on a chart by chart basis it worked. My final question is "why" this was different then just clicking the button that says to include old data? Seems like the rules changed. |
[2014-06-16 09:48:27] |
The way in which Continuous Futures Contracts are now built is very different and it is more organized, has more features, and much more faster and efficient.
