Date/Time: Tue, 22 Apr 2025 06:43:19 +0000
VbP, Chart Values coloring issue
View Count: 282
[2023-03-01 12:23:07] |
BillyVLLR - Posts: 16 |
Dear support team, I see that "Bid and Ask Volume Coloring (In:49)" uses colors set into "Subgraphs>Volume Numbers Text Color and Size (SG7)". Unfortunately, "Chart Values (In:5, In:94-97)" doesn't properly use these colors when we set two colors and use the "Based on +/-" Auto-Coloring option. For example, "Imbalance %" should distinguish between negative and positive values and code the text correctly (as it does for "Bid and Ask Volume Coloring"). Is there a workaround? Best wishes, Billy |
[2023-03-01 14:19:46] |
Sierra_Chart Engineering - Posts: 19293 |
This is not supported.
