Date/Time: Sat, 01 Mar 2025 01:31:42 +0000
Adjusting drawings after rollover
View Count: 2715
[2014-06-13 12:35:06] |
darkpool - Posts: 39 |
Hi, Is there a way to automatically adjust all the drawings after performing a rollover? When rolling over from one contract to the next, there is generally a difference in price between the two. So after the rollover, we have to sit going through every single drawing on every single chart adjusting it to the correct price. Very time consuming. Certain platforms have an option which you specify 'adjust all drawings by X'. So if June ES is 7.25 points above September ES, you will specify to adjust all drawings down by 7.5 points. This is generally needed for things like horizontal rays, lines, rectangles etc. Thanks. Date Time Of Last Edit: 2014-06-13 12:35:42
[2014-06-13 16:38:23] |
This does not exist but we will see about adding this.
[2014-07-15 20:31:51] |
Al SC Developer - Posts: 434 |
In ver 1161, there is a new Adjust button in the Manage Char Drawings Window. You can select either the symbol root of the tree to adjust all drawings for the selected symbol or select individual chart drawings within a symbol to adjust select drawings.
[2014-09-12 08:01:25] |
I have just had the chance to use this function for the first time on the current rollover. Worked like a charm. Thanks.
[2021-09-10 15:30:50] |
User849502 - Posts: 355 |
were exactly is manage char drawings window??
[2021-09-10 15:44:18] |
John - SC Support - Posts: 38292 |
Tools >> Manage Chart Drawings Window. Refer to the documentation here: Chart Drawing Tools: Manage Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
