Date/Time: Tue, 22 Apr 2025 06:51:31 +0000
[User Discussion] - FXCM data has gaps
View Count: 324
[2023-03-01 08:43:06] |
Foreman Capital - Posts: 7 |
Almost everyday I see gaps in my overnight FXCM CFD data. What can I do? The chart session is not the issue.
[2023-03-01 08:43:21] |
Sierra_Chart Engineering - Posts: 19293 |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart It is possible the data is just not available for the particular symbol at particular times. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 08:43:46
