Date/Time: Tue, 22 Apr 2025 07:59:53 +0000
Data for DXY
View Count: 817
[2023-03-01 07:54:00] |
maxm1987 - Posts: 119 |
Hi sierra my question is if there is a way to display dxy data? |
[2023-03-01 18:11:52] |
We do not have data for ICE. It looks like you are connecting to Rithmic for trading, you can see if you can get the data from them. There are other options, such as the USDX (FX Indexes) and USDOLLAR (CFDs) that we offer. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-01 19:04:18] |
Sierra_Chart Engineering - Posts: 19302 |
Use the symbol USDX.
