Date/Time: Sat, 11 May 2024 05:59:25 +0000
[User Discussion] - Range Highlight
View Count: 1598
[2013-05-01 17:51:04] |
apollofl - Posts: 95 |
Is Their a study to highlight a range? for example 20 - 30 tick range. that i can just type in the price? I know that you have the rectangle and extended rectangle that can be used.
[2013-05-01 21:12:21] |
Have a look at the Horizontal Lines study.
