Date/Time: Tue, 22 Apr 2025 07:22:14 +0000
DOM Upgrades
View Count: 354
[2023-03-01 03:59:25] |
Profile Trader - Posts: 177 |
SC, Awhile back I remember reading that DOM upgrades/Facelift was in the works. I have been watching for it and did a search on the forums for a progress update or timeline but could not find anything. Wondering how things are progressing on this front. With the direction of Teton order routing I would assume this is inline with the progress SC is focusing on. Thanks in advance for any insight on the progress of this variable.. Doug Date Time Of Last Edit: 2023-03-01 04:16:40
[2023-03-01 08:24:22] |
Sierra_Chart Engineering - Posts: 19294 |
Not sure what you are referring to. Gradually we have been doing some work on enhancing Control Bar to support many of the buttons and displays and functionality of the Trade Window. So that can be used as an alternative to the Trade Window. Not referring to the other parts of a Trading DOM. Some work has been done on this. Otherwise, there are definitely no changes planned at all for the Trading DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 08:25:26
