Date/Time: Sun, 24 Nov 2024 17:20:15 +0000
Difficulté pour avoir les flux du marche HKFE
View Count: 377
[2023-03-01 03:58:29] |
User934880 - Posts: 5 |
Bonjour, ce jour j'ai fais 2 paiements sur mon compte d'un montant de 36$ et l'autre de 38$ . J'ai fais ausi un mise a jour en passant du pack 5 au pack 11 pour un montant de 41$/mois malgres tous cela je n'ai toujours pas les FLUX sur le graphique HKFE et je n'ai pas non plus le DOM . pourquoi ca ne marche pas ? Besoin d'aide. Je veux active le marche du HKFE avec les données dans le DOM , le volume profile et le market profile et le footprint. |
[2023-03-01 16:39:05] |
From Google Translate: This day I made 2 payments on my account of an amount of $36 and the other of $38.
I also did an update from pack 5 to pack 11 for an amount of $41/month Despite all this I still don't have the FLUX on the HKFE chart and I don't have the DOM either. why it does not work ? Need help. I want to activate the HKFE market with the data in the DOM, the volume profile and the market profile and the footprint. You have not setup the HKFE exchange. To get this data, you need to use the Sierra Chart exchange Data Feed and activate the HKFE exchange. Follow the instructions at the following link: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Also, be aware that will be discontinuing the data for the HKFE at the end of March, 2023. So you will only be able to get the data for one month from us. Refer to the information here: Discontinuing of Old Sierra Chart/Barchart Exchange Data Feed | Replacement Data Feeds! For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-08 12:19:23] |
DELLON - Posts: 1 |
Bonjour je souhaite activer le pack 10 et de ne pas bénéficier de la version gratuite. Bonne réception |
[2024-05-08 15:00:46] |
From Google Translate: Hello, I would like to activate pack 10 and not benefit from the free version.
You can change to a paid package at any time. Follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
