Date/Time: Tue, 22 Apr 2025 06:54:15 +0000
Getting enourmous volumes in my number bars.
View Count: 410
[2023-03-01 00:43:29] |
User758067 - Posts: 6 |
Enormous* pardon. I've checked the forum for similar posts and video tutorials haven't been much help. I am looking at a very illiquid asset with a very slow market, yet the volumes are huge at each given price and in fact are larger than the daily volume reported by the exchange (binance). I've added a picture. FYI, The number in the orange box is the countdown timer. https://www.sierrachart.com/image.php?Image=1677631319185.png Date Time Of Last Edit: 2023-03-01 00:44:22
[2023-03-01 15:40:26] |
Wanted to add that I already use tick by tick data and SC data all services is selected.
[2023-03-01 22:55:36] |
The data we are getting has a volume that is 10000x due to how we have to deal with it. Refer to the following: Cryptocurrency / Bitcoin Data and Trading Services: Notes You can set the Chart >> Chart Settings >> Symbol >> Volume/Open Interest Multiplier to .0001, but you will lose some information in the process. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 23:01:09
[2023-03-02 18:19:11] |
Thanks for your response I was going to actually post this solution, this is actually what I had initially been doing, but I heard that this was just done to improve the readability of the volumes and not for the purpose of correcting them, so I concluded that the un-adjusted volumes were correct until I compared the numbers more closely with the exchange volumes. Anyway thanks.
