Date/Time: Tue, 22 Apr 2025 06:45:59 +0000
Multiple Targets
View Count: 568
[2023-02-28 16:48:14]
User956467 - Posts: 30
Can someone point me in the right direction?
How can I achieve 11 targets with one stop for the entire position and remaining position as targets are hit.
Thanks!
[2023-02-28 18:09:13]
John - SC Support - Posts: 39395
Set the OCO Group for the Stop in the Targets tab of the Trade Window, to All OCO Groups. Then add as many Targets as you want. Refer to the following:
Attached Orders: OCO Group (Group)
[2023-02-28 19:00:34]
Hi John,
I have used the approach you recommended above for years.
But, it seems to be limited to 8 targets and an All OCO Groups stop.
I would like to achieve 11 targets with the All OCO Groups stop.
Thanks for your help, Paul.
[2023-02-28 22:25:08]
Sorry, we did not catch on to that particular item. The Trade Window is limited to 8 total OCO groups, which in turn means you can only have the 8 targets as you have found.
[2023-03-01 00:22:56]
Can I use the spreadsheet study for trading, or is there another way to open a position with more than 8 targets and a stop?
[2023-03-01 16:05:29]
Sierra_Chart Engineering - Posts: 19293
No this is not supported.
[2023-03-01 20:14:22]
User90125 - Posts: 715
You can always set your extra targets and stops ONE tick above and/or below.
Then drag and/or move them to achieve what you desire.
