Date/Time: Tue, 22 Apr 2025 06:59:46 +0000
chart data paused on Feb 21 2023
View Count: 354
[2023-02-28 16:09:48]
User691056 - Posts: 4
Hi, all my chart data paused on Feb 21 2023, see attached pic. can you please check
imageScreenshot 2023-02-27 224700.png / V - Attached On 2023-02-28 16:09:40 UTC - Size: 106.4 KB - 85 views
[2023-02-28 17:16:40]
Sierra_Chart Engineering - Posts: 19293
You are not using the correct symbol. Translate the symbols with this command:
Edit Menu: Edit >> Translate Symbols To Current Service
