Date/Time: Tue, 22 Apr 2025 07:14:16 +0000
Cancel All on mouse
View Count: 392
[2023-02-28 15:52:48]
Steve Leon - Posts: 312
I tried to figure out a way to use the right click on my mouse to Cancel All orders
Is this possible ?
Thank you
[2023-02-28 18:07:00]
John - SC Support - Posts: 39395
You can add the option for "Cancel All" to the Chart Trade Menu (Global Settings >> Customize Chart Trade Menu). Then when you right-click, it will show up as an option. Refer to the following for more information:
Global Settings Menu: Customize Chart Trade Menu (Global Settings menu)
[2023-03-01 01:29:27]
is there a way to add the cancel all under Chart DOM settings > Order Types; under value section so that you can just click on the mouse and cancel all without having to select from menu. I already have cancel all on my numeric keypad i was just looking for a way to put it as a direct function on the mouse ?
Thank you
[2023-03-01 16:15:24]
Sorry, but this is not supported at this time and there is no other option for setting up "Cancel All" using a single mouse click. The fastest is the keyboard shortcut that you have setup, or you can setup a Control Bar Button.
