Date/Time: Fri, 29 Nov 2024 05:42:03 +0000
Quote board and spreadsheet
View Count: 300
[2023-02-28 15:50:37] |
Steve Leon - Posts: 301 |
Is there a way to show values from a chart on the quoteboard using a Spreadsheet ?
[2023-02-28 18:04:56] |
The Spreadsheet Study does this. It gives you the Bar information and any studies that are on the chart. Refer to the following: Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-01 05:08:28] |
User90125 - Posts: 715 |
Check this out too: Quote Spreadsheet Settings
