Date/Time: Tue, 22 Apr 2025 06:59:46 +0000
Delta Bars
View Count: 360
[2023-02-28 14:59:01] |
User491428 - Posts: 87 |
Hello, how is it possible to configure a delta bar the same as in the picture
[2023-02-28 17:55:21] |
Do the following: - Add the Bid Volume vs Ask Volume study to the chart. - In the Subgraphs for this study set the Bid Volume and Ask Volume Draw Style to Ignore. - In the Subgraphs for this study set the Difference Draw Style to Bar and set the Width to a value you want (such as 4 or 10). - For the Difference subgraph set the Auto-Coloring option to Based on +/-. Then set the colors to what you want (first color is positive values and the second color is negative values). Adjust any items from there as you want them. -- We see that the image shows Candlesticks and not "bars", as there are wicks, but we are not sure exactly what is being represented by that in the image you show - so we are not sure if there is a different study that might be more what you are looking for. If you can explain the wicks then we can point you in the right direction. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
