Date/Time: Tue, 22 Apr 2025 07:27:49 +0000
Subrgraph Transparency level variation with ACSIL
View Count: 411
[2023-02-28 12:59:48]
BenjFlame - Posts: 337
I didn't find the syntax to change the transparency level of a subgraph.
In the defaults, I have set sc.TransparencyLevel = 50;
But I want to change that value within the code further down.
Is it possible?
[2023-02-28 17:26:22]
John - SC Support - Posts: 39395
It's the same variable. Just change it where you need it/want it changed.
