Date/Time: Tue, 26 Nov 2024 19:45:37 +0000
NZDUSD - cannot show chart
View Count: 1126
[2014-06-13 07:32:18] |
User60841 - Posts: 2 |
Hello - When I upload NZDUSD charts - I can see only 1 minute charts - another charts dont show - see attach Hope you help me fix this problem thank |
Снимок_экрана_061314_012929_PM.jpg / V - Attached On 2014-06-13 07:31:49 UTC - Size: 755.68 KB - 348 views Attachment Deleted. |
[2014-06-13 07:41:38] |
This is now resolved. Go to the charts that do not look right and select Edit >> Delete All Data and Download. This only needs to be done once for each symbol you have an Intraday chart open for.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-13 07:42:26
[2014-06-13 07:49:49] |
THank you - now all done
