Date/Time: Tue, 22 Apr 2025 06:57:06 +0000
[User Discussion] - Issues with orders
View Count: 291
[2023-02-28 10:41:17] |
mark barnard - Posts: 2 |
Morning, Im having issues placing orders how i would like to. Basiclly i would like to be able to place orders as follows, If i wasnt to sell 2 contracts at 4253. i want to be able to either market or limit order (depending on market conditions) then not have a set stop or target. I then wish to be able to set my own stop manually. Then when market falls to a area i feel its time to get out i wish to be able to place a buy order to exit the position. All of this will be performed straight on the DOM also. Not a chart. At present i have managed to place orders which have no stop or target but when it the market placing a Buy/Sell order to act as a stop doesnt do this. When the oder hits there it basically reverses the action. Same goes for a target or take profit. I place an order and it markets me out of the position immediately. It does not place a limit order. I hope this makes sense. I cant really explain it any better i dont think. Thanks, |
[2023-03-01 09:28:48] |
Sierra_Chart Engineering - Posts: 19293 |
Really we definitely recommend always using Attached Orders: Attached Orders You can keep the Stop and Target orders, further away than maybe where you might want to put them, and adjust them later. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 09:29:15
