Date/Time: Tue, 22 Apr 2025 07:54:29 +0000
Horizontal Line at Time
View Count: 411
[2023-02-28 02:31:28] |
fish4trout - Posts: 99 |
I have several times marked on my chart. However, when I scroll back let's say to the day prior, I don't want these to be plotted looking back. So I only want them plotted for the current time and then extended into future by 24 hours. Is it possible to only plot them from current and forward 24 hours?
[2023-02-28 16:25:33] |
You could use a Color Bar Based on Alert Condition to check whether a bar is part of the current date and then set the color to what you want, and set it to the background color otherwise. Refer to the following: Color Bar Based on Alert Condition Or you could use the Spreadsheet Study and do the same thing by only displaying the data for the current using an IF statement. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#IF_Function Spreadsheet Functions: Serial DateTime Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-28 16:36:22] |
You could use a Color Bar Based on Alert Condition to check whether a bar is part of the current date and then set the color to what you want, and set it to the background color otherwise. Refer to the following: Color Bar Based on Alert Condition Or you could use the Spreadsheet Study and do the same thing by only displaying the data for the current using an IF statement. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#IF_Function Spreadsheet Functions: Serial DateTime Values Or you could modify the source code so it only calculates the lines for today. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-01 00:28:29] |
OK thanks, I'll give those suggestions a try!
