Date/Time: Tue, 22 Apr 2025 02:24:33 +0000
Question on settings
View Count: 353
[2023-02-27 21:44:20]
maxm1987 - Posts: 119
Dear Support
1) can you please have a look at the chart "Trigger24 PnF" and tell me why it displays a developing POC even though the setting is deactivated?
2) can you please have a look at the chart "30 MIN ETH". My question are
- why is the POC for the individual day sessions connecting to the next via a straight line?
- my second question is why both horizontal line studies are connected via lines from previous sessions? my desired result is that the lines are drawn from scratch in each session and do not have any connection with previous sessions
thank you
attachmentChartbook10.Cht - Attached On 2023-02-27 21:43:33 UTC - Size: 20.61 KB - 165 views
[2023-02-28 15:32:39]
John - SC Support - Posts: 39395
For the VbP that you have set to not show the developing POC, it is not. And for the VbP that you have set to show the developing POC, it is. In other words, your multiple Daily VbP's are not showing the developing POC, but the 1 VbP at the end of the chart is showing it as this is how they are set.
Change the Draw Style from Line to Dash. Refer to the following:
Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH)
