Date/Time: Tue, 22 Apr 2025 02:24:35 +0000
Data
View Count: 303
[2023-02-27 21:24:46] |
dcarrionlevy - Posts: 4 |
Hello I have an account connected with teton data since i trade futures with stage 5 directly off sierra I am trying to chart fx (normal not futures) And I cant Is there a possibility to chart futures and fx at the sametime or do I bave to disconnect the currect data feed and connect to the regular Thank you |
[2023-02-28 15:11:06] |
You should have access to our FXCM FOREX data. If you go to File >> Find Symbol do you have the section for Forex - FXCM showing? And if you open that you should see all the pairs available and be able to open a chart for one of them. Let us know if this is not working and what you are getting.
