Date/Time: Tue, 22 Apr 2025 02:21:40 +0000
Continuous Charts
View Count: 303
[2023-02-27 21:22:01] |
UFODetective - Posts: 10 |
Hello, I'm trying to apply continuous volume to my charts. Take the 30 year bond for example, I can only go back to 2017, no earlier than that on the monthly, even though I have over 2000 days to load historical chart entered in. I've got the Denali package in my account. Something I'm missing?
[2023-02-28 00:01:15] |
Which 30 year bond are you using (what is the symbol)?
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-28 07:39:11
[2023-02-28 08:24:02] |
Sierra_Chart Engineering - Posts: 19290 |
This is because you are using Rithmic and Rithmic uses single-digit year symbols. Refer to the information here: Continuous Futures Contract Charts: Limitations And item 3 for the solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
