Date/Time: Tue, 22 Apr 2025 02:24:33 +0000
Turning a chart into a region in another chart
View Count: 613
[2023-02-27 20:57:10]
dberliner - Posts: 16
I have a small chart I use as confirmation on my main chart. Is there a way to take the chart "as is" and turn it into a region 2 or 3 etc. under the main chart? If so couldn't find out how to do it. THank you!
[2023-02-27 23:55:47]
John - SC Support - Posts: 39395
There is not a way to take an entire "Chart" with all the studies and markups on it and have it display in another chart's region.
But, you can use multiple copies of the Study/Price Overlay to get the Main Price Graph and any studies from the other chart into a region on another chart. Refer to the following:
Study/Price Overlay Study
[2023-02-28 09:00:53]
Sierra_Chart Engineering - Posts: 19290
Also refer to:
Add Additional Symbol
