Date/Time: Tue, 22 Apr 2025 02:24:36 +0000
I enabled denali data feed for CME but i do not get data
View Count: 292
[2023-02-27 17:37:45] |
User866347 - Posts: 4 |
I enabled denali data feed for CME but i do not get data how long does it take to enable it? i am connecting to a live CQG account running version 2480 here is the log if this helps resolve the issue |
![]() Attachment Deleted. |
[2023-02-27 18:59:07] |
You have not activated any exchanges for the CME Group. You can activate the exchanges you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
