Date/Time: Tue, 22 Apr 2025 02:18:41 +0000
symbol invalid
View Count: 463
[2023-02-27 16:28:49] |
luciana - Posts: 24 |
Hola Me conecte a la red CQG pero me arroja este mensaje. No se que estoy haciendo mal. Me pueden ayudar. Gracias |
[2023-02-27 18:36:24] |
From Google Translate: I connect to the CQG network but throw this message.
I do not know what I'm doing wrong. Can you help me. You are not using the correct symbol for CQG. Open your chartbooks and then select Edit >> Translate Symbols to Current Service to update the symbols to what is needed for the currently selected service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-28 10:52:19] |
hice lo que me dijeron pero ahora me sale este mensaje. Como puedo lograr conectarme a la red CQG y recibir datos para micro E mini SP 500 en tiempo real para poder hacer trading? Gracias |
[2023-02-28 15:00:55] |
Sierra_Chart Engineering - Posts: 19290 |
We needed to activate the CME exchange for your account. This is now done. You should begin to receive the real time data now. You may need to wait a few minutes. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
